Decal/Polishing Question
dschribs
Active member
I have this decal on my hood.
Would you guys recommend just polishing around it, polishing over it or taping it up just to be on the safe side?
if I do use tape, will low tack painters tape be ok? I am sort of paranoid about taping it up then having the tape pull off some of the actual decal...
Thanks!!!
It is a "factory applied" decal, correct?
You talk of "polishing", are you going to use a rotary, a DA or by hand?
With a DA or by hand, just polish right on over it, won't hurt it one bit unless you are using a harsh compound and "bear" down on it.
Use a soft bristle brush after polishing to remove any residue from around and in the letters.
Grumpy
I agree with Grumpy, but if you do decide to tape over it, I have used the blue painters tape on all types of decals and never had a problem with it lifting them.
Thanks guys. Factory decal and I'll be using a DA with Meg's 205. Car doesn't need any more than that.
