baker
Thinking of taking the A3 and 2.0 from the rear of my A3. Are they held on with adhesive, or is there something that will leave a hole that must be filled. If adhesive, is a hair dryer enough to remove them? Thanks for any input.
Accumulator said:BAKER- Cool idea, I debadge all our Audis (some to a greater extent than others).
I use a combination of 3M Adhesive Remover and a hairdryer. Sliding some waxed dental floss between the badge and the panel will help pull it off once the adhesive is compromised (DO NO use a screwdriver/etc. instead) and will help you determine if the badges are pinned on.
Think twice about removing the Audi rings. I like how completely badgeless looks, but plenty of other people prefer leaving the rings on. I took everything off the S8 and left the rings on the A8, and most people like how the A8 looks better (but not me, so do what *you* think looks best).
IME all the badging is glued on, but I really dunno about A3s :nixweiss I'd sure be surprised if they were pinned though. You could always go to the dealer and check out the emblems, make sure they don't have pins (or ask an Audi dealership bodyshop).
IF the badges *are* pinned on, you can almost always just put 'em back in place. I had this happen with a Subie..one badge pinned, the others glued, and I just stuck the pinned one back in place. As long as you don't bend/etc. it (use the floss method to help prevent that) you shouldn't have any problems. But man would I be surprised if they weren't just glued on...
Mark77 said:I like it, good you left the rings there.. looks a bit too naked without them IMHO.
