Danase Speed Shine
Russecu
Since the reviews section is closed I will post here. I have tried many QD's and I keep going back into my stash reaching for the Speed Shine. This product does and excellent job as a QD and leaves the finish slick and glossy. I used it after my wash to give that extra gloss and slickness. I have also found that it have some cleaning ability too. I like to use it when wiping down door jams and such with a MF towel and it leaves anice clean look there also. I have used Meguiars QD and a mixture of DP 4-in-1 and I believe I have found my go to QD. Yesterday when I was preping a car for polishing I was claying at first using the 4-in-1 mixed at the QD ratio. It seemed to make my clay detiorate a little quicker than normal and the claying was not going a quick as normal. It was a white car so the contaminants show up more easily tha other colors. So about half way through I switched to the Speed Shine and it seemed to improve the the ability of the clay. seems as if the clays glided more easily and picked up contaminants more effectively. I use it on my black truck and I do not see any streaking when using it as a QD. I spray, wipe, flip, and wipe again. I have some PB S&G and I think the Speed Shine gives the same looks or better and is more versatile. Forgot to mention it smells great too.
Bioman said:
What are the differences between yours and theirs?
Our formula leaves the surface a little bit slicker and has just a tad bit more cleaning ability. The added cleaning ability works great for bird dookie and stuff like that.
dookie :LOLOL
dookie :LOLOL
I forgot to add that I do keep a small spray bottle of this in my truck with a mf towel just for emergencies like poop. Cleans it well.
I'm confused -
Chemical Guys ( I assume that's "CG") Danase AND Griots all make a QD called "Speed Shine?"
Where are the trademark lawyers when you need them?
Rockfish66 said:
I'm confused -
As far as I know Chemical Guys doesn't carry anything called "Speed Shine".
What are you QDing over? That makes a difference.
Most of the time I use it for claying and after my wash and I have went over the vehicle with my waffle mf to dry. I use another waffle mf to use the speed shine and I spray and wipe and flip and wipe to remove excess. This is to give a gloss look and to keep the shine inbetween waxes. I also use it to quickly wipe down every other day or so if it hasn't rained. I however do not use it after a rain or for a waterless wash. I do not really trust anything to be a waterless wash. I haven't even gathered the nerves to use ONR/4-in-1 for a wash. What do you really mean by qding over? Are you wanting to know sealants or waxes used or just general dust/dirt/grime? I agree it does help to have a polished and sealed/waxed paint because that does help resist the poop, dust ,etc.
