Cyclo Duel Head Orbital Polisher
The Cyclo Polisher is the only dual-head polisher on the market. Both heads move in an orbital motion, counter clockwise. The idea is to simulate hand polishing but at a much faster rate. Going over a scratch or swirl with both heads ensures that you are attacking it from all sides, so to speak. It is not an inexpensive machine ~ 300 USD but it does cut down on vibration significantly
It has been proven that operators face significant risk of muscle, joint and nerve damage caused by the inherent vibration of power tools. By reducing the amount of vibration you can reduce muscle and joint fatigue as well as the potential risk for permanent damage, as described in ISO 5349-1:2001- Mechanical vibration -- Measurement and evaluation of human exposure to hand-transmitted vibration.
One unique feature of the Cyclo Vibration Elimination System (VES) is that it is tuneable; the system's engineering allows the user to match the VES system to the various attachment systems available for Cyclo Dual Head Orbital Polishers - rubber pad holders or bonnets, carpet and scrub brushes, quick connect adapters with Double Precision™ pads, or other Genuine Cyclo attachments. This is achieved by selection of VES weighted inserts. Each weighted insert has been precisely machined to match and offset the vibration created by the orbiting action of attachments. By matching the correct VES weighted insert, operators reduce muscle and joint fatigue as well as the potential risk for hand, muscle and nerve damage.
In addition to the reduction of potential harm to the operator, the VES increases the polisher's stability during operation. Less vibration results in more consistent contact between the polisher heads and the surface being polished. Owners will benefit from a polisher that applies product more evenly and consistently and produces a higher quality finish.
Balance and Vibration Elimination
The dual orbital action heads produce an overlapping motion that simulates gentle hand-rubbed quality and eliminate the danger of heat build-up or swirl marks, with exceptional stability and smooth operation. The machine responds to pressure applied and polishes painted or unpainted surfaces with maximum safety and efficiency. It has two heads, spinning in opposite directions, so the machine remains balanced and produces minimum vibration
