vdubbya
Rochester Auto Spa
How many people use compressed air to blow out the interior of the vehicle you're working on or in drying cracks and what not? If you do, what is a suitable sized compressor?
Just a suggestion.vdubbya said:How many people use compressed air to blow out the interior of the vehicle you're working on or in drying cracks and what not? If you do, what is a suitable sized compressor?
Clean Dean said:I have a couple of the Husky portable 90 PSI models that they sell at HD for about $100. ....
From what I have read, this is correct...both the frequency of the action and the reason for same.tubafeak said:... In response to how often you should purge the tank, it should be emptied every time you use it, once you are done. If you don't relieve teh pressure then water can be forced in to the cylinder walls. Rust-through is a real problem ....
Mr. Clean said:Another question about the HD Husky units. I went out to HD today and looked at the unit, but did not see a "bleeding" valve. The Porter Cable units have one at the bottom of the tank and recommend opening frequently to allow condensation to be released.
Another question who has the best blow gun attachments? HD's offerings were scant (2). Neither had a rubberized tip.
DShiznitz said:You could also consider using Plasti-Dip and make your own protective coating for the whole gun.
Mr. Clean said:Good thought.
Pats300zx, how is that unit working out for you? How is the noise level? Does the unit produce the amount of pressure to do the things you intended?
Clean Dean said:My experience with the Husky units...
I have three of these, and two of them came with a handle for easy manuvering (newer models). They are ideal for the mobile professional, but the hoses are too easily damaged. I keep an extra hose on both of my mobile detailing vehicles. I have been through about 3 hoses in the past 6 months.
Are these units fairly new to you? The coiled hose that comes with them feels like it will become brittle quickly. Can I assume that the 3 hose failures were the original hoses and not replacements? Do you have a replacement hose mfg recommendation.
