I inquired about V.O.C. regs & comparisons of #476s, #885, and #915 and received this response from Mike Oczkowski, Collinite Customer Service. Some comments reflect typical mfg bias but some useful information here:
"Because of the new VOC regulations we are going to have to tinker with of formulations. The only problem we might have is that the product might take a little longer to set up or dry, other than that the product will still outshine and protect better that other waxes.
I would recommend stocking up to be on the safe side. With the cold weather upon us, I recommend storing the product inside at room temperature."
"The #476s is supposed to be hard, sometimes they do come out a little on the soft side, but you would prefer it to be hard. The main thing is that all you need to protect the car is a thin layer of wax, you do not have to glob it on. If the water is beating up on the finish and running off while you are driving everything is fine.
The #476s and #885 are the exact same product, just a different size and lithographed can. The #915 basically comes from the some formula as the #476s & #885 but is has approximately 24% more carnauba wax and contains a coconut fragrance.
Appearance wise there isn't a major difference between
the #915 & #476s. I usually tell people the purchase the #476s to save money and still get a great car wax.
I do not have the carnauba % of these products available."
