Cleaning Greasy Door Hinges
For door hinges and that whole area I use one of those lambskin finger mitts from Griot's and I just use some car wash. If it is stubborn, I use whatever degreaser I have around.
The finger mitt allows me to get in all the nooks and to put some pressure on the stubborn areas.
I then use one of those insecticide sprayer things that they sell at home depot to "hose" the area down. A gentle stream gets all the areas clean without getting the interior wet. I then wax the painted surfaces and spray some Trim Shine on any visible "black plastic."
The car wash guy won't do that for you.
On the subject of door hinges, I wish somebody would create a new tool that is specially designed to clean door jambs and trunk jambs. The wooley's are OK for now but I'm looking for something better.
A 25 degree tip is what I am currently using and I get no water on the interior and at the least a little mist on the thresholds.
You also have to be using it up close and be quick yet effective.
I have a Troy Bilt (gas unit)
Are you at all afraid you might be removing some needed lubrication? I have used a steamer to remove the surface grease that worked it's way out but never a pressure washer.
Thanks Everyone. Don't have a pressure washer yet but will try the ideas here. DC...good to hear from you, hope you are splendid!
Thanks FB ! Im not really splendid but have many splendid moments , thats enouh for me :D Hope your doing great as well!
Please post the product names and dilution ratios you use if you would be so kind.
Sure!Sorry I didnt see this post earlier.
ALLBRITE tire and wheel cleaner strong degreaser ( the bomb on grease)1:4 or stronger as needed
MAINTEX Safe D'orange degreaser/deodorizer (general APC)also great for carpet cleaning 1:5 or stronger as needed
That sounds really good. I'm going to give it a try with my electric Karcher, but I don't know what type of tips I have.
I do the same thing. Spray it with degreaser and rinse it with a pressure washer. Place it close and do it some what quickly. It leaves very little water elsewhere.
JG
