Cleaning glass with newspaper...
BRUHA
Does anyone here use newspaper (and either water or glass cleaner) to clean your windows? I have heard that the ink on the newspaper actually acts as a polish on the glass. I used the newspaper and water in a spray bottle to clean my glass. It seemed to have scratched the hell out of my windows and mirrors. They could have been there before (and I just never noticed them), but I'm not sure. Can newspaper scratch your glass?
I tried the newspaper idea once and hated it. Plus, the ink can run and end up on your dash, seats, or carpet.
Yeah newspaper sucks! Just wash with rest of car and dry with a good MF and you're set. Hit the inside with a slightly damp MF and follow with a dry one.
I think with MF being used so widely and the great results it produces, there is little reason to use anything else for cleaning windows.
Just add some Stoners Invisible Glass and you will have perfect windows without having black ink all over the place.
Stoner's suggests newspaper on the back on the can. Personally i get better results with newspaper, never see any black ink.
bigron - what is happening????????????
I can't believe you are passing up an opportunity to push your favourite product!!
Newspaper ink used to contain a product that proved to be carcinogenic. I am having a senior's moment and can't remember the name of it (it was also used extensively in electrical machines like transformers and capacitors). It has been banned.
Newspaper ink, no longer containing this nasty component, has lost it's ability to clean glass like it used to in your father's and grandfather's age.
Stick with microfiber (uF - uF; see that everyone, I'm not giving up on this one!!!!!!!!!!!!!)
Newspaper contains black ink that is made of small particles. These small particles act to "polish" the window. If you google india ink, NASA, and aluminum, you will find NASA's method used to polish aluminum to a high mirror finish.
I used newspaper last week at the beach. I brought glass cleaner but no towels. The newspaper worked pretty good, but the glass cleaner caused the ink to come off on my hands.
Newspaper will work great. The only drawback is it leaves your hands pretty nasty. I use microfiber now. Not better results, but cleaner hands.
I've always used newspaper & tolerated the dirty hands I was left with. I assumed the streak-free polishing was being done by the newspaper itself which is a bit coarse and not the ink.
If you tried to clean with laser printer paper, either with printing or blank, you'd find the polished surfaces of the paper just push the glass cleaning solution around so it must be the coarse quality of the newspaper, right?
Recently, the Buffalo News changed over to new presses that require better quality paper and it cannot be used to clean glass. If I use my local town newspaper (old-style paper) I still get excellent results .... and dirty hands.
The difference is the quality of the paper, not the ink on the paper.
