Ok, everything finally came together and I got a perfect day to work on the car. After a Dawn wash I polished some touch up areas I painted last weekend and did a little buffing before starting the Zaino routine.
The Proshine rechargable buffer is the first buffer I've ever used. On the one hand my lack of experience makes it hard to compare to other units, on the other hand I got excellent results with no prior experience.
There are 2 battery packs. By the time the second one ran out I had buffed the panel where I did the touch up and also buffed all horizontal surfaces (hood, top and trunk). If I had really wanted to do the side panels I could have used the cigarette lighter power cord, but I didn't want to do that and the side panels were ok anyway.
This buffer is not designed for heavy duty use, but it is comfortable to hold and seems ideal for light use. The Porter Cable unit is probably much better, but for those of us with no convenient power supply this buffer fills a niche. I give it a "thumbs up".
:up
