Clay Bar Idea
I'm also using blue Clay Magic with BodyShine (even dilluted 1:1 with water) with great results. I'm thinking that if you do not like it, don't buy it. You in USA have so much products available that you can choose...
budman3 said:
I've used several clay magic blue clay bars (seen below, yes I used their lube) and every one of them were either hard and very hard to work with or fell apart. I tried the clay again with the same results. I was not impressed so no more clay magic for me. I even bought a pack in Florida and still the same.
Hopefully they will do something about this clay because right now you won't see me buying any. With my experiences there are many superior clays available which may cost a little more but you get what you pay for.
For someone that thinks Clay Magic is so inferior and bad, you sure have jumped through hoops using it? Especially when there are so many other superior clays to choose from. In prior posts you've mentioned using Opti-clay, Poorboys & Mothers with good results, but you still continue to keep trying Clay Magic? Looks like you're a "sucker for punishment". :confused: :D
I kept trying the CM because I wanted to see if I had a bad batch or not. CM and Mothers are the only clays availible OTC in my area and it'd be nice to pick up a clay bar at a store if i needed it. With CM at about $12 and Mothers at $16 I figured I would use both and see which worked better. The CM didn't work the way I'd like so I gave it another chance. I gave it three strikes and now it's out. So hopefully they will change the formula. If they have a new clay come out, I'll try it and see how I like it. If I like it great, if not, there are alternatives.
