Certificate of Completion
I might of posted this before, but I wondered if anyone else gives their customers a list fo work performed so they are better educated? here is mine.
Here is a list of the work I perform and a copy of the documentation every owner gets when I detail a car.
On this date the following work was performed by Perfect Auto Finish
Inspection of car
Engine cleaned and dressed
Hand washed (two bucket method)
Chemical removal of tar, overspray, road paint if needed
Hand washed again
Clayed (all paint, glass, wheels)
Washed again
Deep cleaner polish applied to finish
Inspection for deeper paint blemishes and scratches
Correction of these imperfections using proper machine buffer and compound
Med-light cut used with proper machine buffer to bring back luster from compounding
Pure polish applied to bring back shine
*last three steps are used only if finish is in poor condition
Final application of finish, paint sealed
Tires are dressed, same with wheel wells
Wheels polished
Detail brush used to remove any residue in-between molding trim
Chrome polished
Tail pipes cleaned, under carriage cleaned, grill front and tail lights sealed
Final inspection of exterior
Interior
Mats removed/vacuumed and extracted
Interior and trunk vacuumed
Forced air used to blow contaminants from under front seats, side door panels, dash, console, side compartments, trim and other areas dust can hide
Head liner cleaned is necessary
Vents cleaned with Q-tips
Dash, door panels, all plastic, vinyl and trim cleaned and dressed
Using a detail brush, all intricate areas are cleaned, console, gauges, and other controls
Seats cleaned and conditioned
Windows cleaned
Rubber door seals lubed with dressing
Door jams cleaned and sealed
Foot pedals cleaned
Carpet second vacuum, then extracted
Wood veneer cleaned and sealed
Chrome polished
Gary Kouba, Perfect Auto Finish
I noticed how you treat the seals, headlights, and wood. Is this your complete detail?
What do you use on the wood?
Jordan
... cleaned as necessary...
Door jambs ...
If you're going to hand a piece of paper to someone, it should be error-free. While it's true that many people won't notice, some will, and there's no point in conveying anything less than perfection.
I treat the wood with a product called poly seal, it removes smudges and finger prints, while leaving a nice protective coating. I treat the rubber door seals with a water based dressing. gary
