Hi all,
i made a new speaker box ( http://forums.vwvortex.com/zerothread?id=1514481 ) to replace my pre-fab box.
the box has been glued and screwed and silicone applied on the inside and outside of the seams. I put some weatherstripping around the speaker opening and screwed the speaker down (JL 10W6, wired in parallel).
i wired everything up and..... was disappointed. using the same gain and bass boost settings on the amp (JBL 300.1) and head unit, the sub was barely audible compared to when it was in the prefab box.
I thought i had reversed the polarity of the speaker terminals, so i swapped that and tried it again, a bit better, i think, but still very quiet. when i used these settings int he pre-fab box, it would be *LOUD*
Would there be that much of a difference in loudness between a cube-type prefab and my box or does my box have a leak or some other wiring problem in it?
or do i just turn up the gain and bass boost on the amp and enjoy
thoughts?
Tim
thoughts?
Tim
