Not intending to :argue but I would *not* think it'd be the wash/dry media. But then I'm assuming that any such stuff has passed the CD-test.
I would think that the marring comes from abrasive [stuff] getting pressed against the paint and then moved. When the stuff is "trapped" in the wash mitt/whatever, it can still come into contact with the paint.
Once you CD-test to make sure the media are OK in the first place, consider whether the dirt gets trapped (and then dragged across the paint) as opposed to being flooded/flushed/etc. across-and-off the surface. If you find dirt in your rinse bucket, consider that between the time it got stuck to/in the wash mitt/etc. in the first place and the time you rinse it out...well, during that interval it's getting dragged across the paint.
I really do think that once you get the hang of it, my (current...somewhat different from the method explained in the first section
of that thead) method goes pretty fast. I'm not sure how much my boosted water pressure factors in, but I'm usually able to do the initial passes (with the BHB) without even stopping to rinse out the BHB; it rinses clean from the foamgun's output.
Yeah, the FK1000P is pretty amazing in that regard. I gave the Yukon a good inspection prior to selling it; after 21 months of merely washing it, it was *still* quite marring-free for a year-round dog-hauler. I could find maybe a dozen light RISS that I would've eventually corrected had I kept it, but they were the sort of thing that *NOBODY* other than an Autopian would ever notice, much less care about.
No, I'm not trying to pat myself on the back here, but rather I'm trying to say it it *is* possible to keep marring to a minimum if you go about it right. It's that "going about it right" that's the trick...from your LSP to your wash supplies to your technique, a lot of stuff factors in.
While others here do fine with ONR, maybe you're like me...I simply cannot avoid marring (to the extent that *I* insist on) when I wash with ONR. I can do OK, but sooner or later I scratch it up in a way I simply don't do with my conventional washes.
I bet I come across as a real ONR-hater, but that's not really the case. It's just that even though I *do* take all the relevent factors into consideration, I just can't keep things perfect with that approach. *IMO* that's because at the bottom line, I'm still getting dirt stuck to the mitt and then moving that contaminated mitt across the paint. Even with ONR's great encapsulation, some of the dirt ends up abrading the finish.
