california "water blade"
PA DETAILER
DETAILED TODAY?
finally got to use one. my opinion was i liked it. i know you have to watch so nothing gets caught in the blade and scratches your surface. it removed 80% of the water. the rest is finished with a drying towel. cut down on drying time, which is a good thing.
Make sure you use that thing with plenty of water on the surface. Also, make sure you've done a perfect wash job! If you miss a spot (some dirt on surface) and that blade slides over that spot... instant swirls/scratches.
Good luck with it.
9chevy4 said:
what about a regular squeechi (sp?) doesnt that work just the same?
Squeegee's blade is made of rubber, which can harden and scratch - not recommended :jump CWB is made of medical grade silicone :)
cool, i already learned a new thing today. Good thing i found this site, u guys rock!
Hopefully, the following was what you learned. It is the most valuable post in this thread. :)
Good luck with it.
Charles
The CWB is much better than a squeegie. If your car is properly waxed then there isn't really a need for one anyway. Just run a slow stream of water over the car and most of it will slough right off.
