Accumulator
Well-known member
Legacy99 said:So what happens when you need a rotary and you only have a Flex and what about smaller pads when you need them?
I have two rotaries, Cyclos, PCs, the Griot's 6" (still NIB), and the Griot's 3".
NOTING THAT I'M NOT A PRO (meaning I only work on my own cars and maybe a few for friends), I've never run across any situation where the Flex couldn't cut it and I had to get out a rotary. Never. Not for sanding scratches, not for serious correction on hard clear.
And I could get by just fine without the machines that take smaller pads, though I could always mount the Edge adaptor on the Flex if I had to. Yeah, small pads are great for spot-correction, I use 'em all the time. But overall I could get by better with just the Flex than with (only) any of the others. Remember that for many years there were no small pads for *any* machines except for the Cyclo.
One of the things to consider about the rotaries is the learning curve, it's much flatter than with RO/DA machines so mastery comes very slowly. Yeah, it's *VERY* easy to avoid burning paint. But it's not so easy to avoid holograms. Even experts with decades of experience (e.g., Mike PHillips ) will tell you that they sometimes have to use a PC/etc. for the final passes to ensure a hologram-free finish. Most non-pros won't do enough polishing to develop the skill of somebody like Mike; they might only do a few dozen corrections over the course of a lifetime. Why not have those few corrections turn out OK without some big skill-developing project?
LanceRomance said:What kind of pads are best suited with the cyclo?
One last plug for the Flex...there are some contours (like on my XJS) that the Cyclo simply cannot accommodate. But hey, far be it from me to dissuade somebody from buying a Cyclo, it's the only polisher I genuinely *enjoy* using. I bet you'll love the Cyclo as much as I do.
I prefer the Cyclo brand pads. They work fine and last a long time. Get some orange ones (not the yellow) for serious work, lots of green ones, and a few white and/or blues. Consider getting the Edge quick-change adaptors, they're a lot more helpful than you'd think.
Yeah, there are other pads that work fine, but I still like the Cyclo ones. Try to stick with *flat* pads, not concave or otherwise oddly shaped ones. The Lake County brand HydroTech pads (now available in 4" IIRC) sound *VERY* appealing and those might be absolutely super; I suspect they'll work out that way but I haven't tried them yet.
And don't neglect the carpet cleaning brushes, they work great.
I doubt I will be doing major paint correction just taking swirl marks, oxidation, and water spots off of surface. Is this type of work a three step process for best results?
If the correction isn't too severe you might be able to get by with just two steps (well, plus your LSP). I'd probably lean towards Menzerna stuff via Cyclo, but the Meguiar's M105/M205 twins are very poplular and work great....I just haven't tried them via Cyclo so I can't give you first-hand feedback. Seems like everything I've used via Cyclo is now antiquated and I'm not sure which newfangled products would be the *BEST* choice for you. But you sure wouldn't go wrong with Menzerna.
The thing to remember is that the Cyclo a) has a fixed speed and b) uses small pads. Both those can factor in when choosing products.
