MooreImpressive
Here in Indy we use a guy that does several of the new car dealers. He does 2 things mostly. Regular paint touch up (brush touching), and minor scuff and scratch repair. Occasionally we'll have him paint a door handle or pillar but mostly it's bumper scrapes and scratches that can't be sanded and removed. He does the same thing a body shop does. Uses a DA to sand the area, then primes and paints. He is very good at blending so you would never guess the area has been fixed. He has a van with all of the equipment like paint guns, air compressor, generator, and also has his own PPG paints that he uses a PPG app on his phone to get the exact mix for, then weighs it on a scale on a drop to drop basis, exactly like a body shop paint room does. This is real base clear, not single stage, so you can still sand it afterwards to get it as smooth as you want but he is good enough that he lays it down very smooth already. He charges around $40 for a full vehicle touch up and between $100-150 for doing the sand/prime/color/clear jobs like OP is doing, and yes this often includes body filler. Makes no sense to try to do it yourself if you have never tried it and are expecting great results, not for those prices.
Far as where to find a person like that, nearly all dealerships that don't have a body shop have to use a person like this, so just go ask a few of them. Most often the same guy will do several dealers in the same area. Shouldn't be hard to find, just make sure they are legitimate. The dealership would probably show you some things he fixed for them.
