jupiter said:Just an update. I polished a few areas with Menz Super Fine and a 4" finishing pad @ 1800-2000 rpm. I'd say most of the holograms are gone and things look better, but it's still not good enough so I ordered a GG polisher.
JohnKleven said:You gotta slow those rpms down when finishing down. I usually run 1000 rpms with Super Finish, and can finish 100% hologram free.
John
jupiter said:What size pad are you using? 1000 rpm on a 4" pad is really slow.
Scottwax said:I'd be pretty surprised if in a few weeks the holograms aren't back along with finger tracers from hand polishing.
And why would you try and finish out with a 4" pad? 6 1/2 to 8" pads work great for finish work.
jupiter said:Why would holograms return? Does Menz SF have fillers?
I prefer 4" pads because they fit the contours of the car much better. If you want the edge of a large 8" pad to touch the car with adequate pressure, that means the center is being pressed very hard. If you don't press hard enough, only one edge touches the car and the pad skips
