Broken PC?!?!
eric77
I was in the middle of detailing a customer's car on Saturday when my PC started to cut out. It would bog down and then completely stop working. I picke dit up and shook it a little and started up for a second or two then died. I am afraid that the motor may be burned out because it will come on for a short while and then just become weak and die. I bought it from coastaltool about a month ago and does know what kind of warranty these have? I need to fix this or get a replacement asap because i cannot work without it.
the same exact thing just happened to me! I wonder how common this is, I was pretty dissapointed (newer pc user) as everyone raves about the quality of the PC. This was only my third detail with the PC. I replaced it with a 7336 from lowes, and this one seems to be ok for now. We'll see how it holds up! good luck
eric77 said:
Do you think lowes or home depot would qualify as an authorized porter cable service station?
no. i believe you have to take it to an actual authorized porter-cable service center so they can inspect/repair it.
If you use it that much it may pay to get Meguiars version of the PC they call the G100, it's a little more but it comes with a lifetime warranty and backing plate and one pad.
true. but.... for the cost, you can get TWO pc's and generally they last for many years without any problems. i guess sometimes it's just an isolated case? :sadpace:
it was just the cord that was broken. had it fixed for $35 because I wasnt about to wait 2-3 weeks for pc to fix it.
Just curious in retrospect do you tug, yank or pull on the cord too much? Not being critical wondering what, if anything, you do that we should avoid?
the cord was really twisted and im sure thats what did it.
Costal tool rocks, they will send you a copy of the reciept if you lost it but you will have to send it to the waranty shop for repair. I know that costal will replace it if it is within 30 days though, they are a class act. oops my bad I meant Mytoolstore rocks, got them mixed up, but if you bought it through the mail you should be getting a 30 day garauntee anyhow, I think it is the law in many states.
http://www.mytoolstore.com/makita/mak08-02.html
imacarnut said:
true. but.... for the cost, you can get TWO pc's ...
That’s only if you compare the Meguiar’s list price with Lowe’s discount price.
Even if you pick up a PC for $100 you still need a backing plate and a real pad. So let’s say one pad and a packing plate cost $25 for a total of $125.
Auto detailing solutions sells the G100 with a backing plate and a W8006 polishing pad for $150. So you get the lifetime warrenty for about $25.
PC.
Check your cord and the brushings. One of my PC7336s died on me and I looked up an Authorized Dealer to have it fixed under the 1 Year deal. Turns out my brushings were just crystallized and needed quick maintenance.
For future reference: All Ace hardware stores are authorized service centers for Porter-Cable products.
eric77 said:
not according to porter cable's website...
That is exactly my source. Every ACE hardware store in my ZIP is listed.
There are many others listed as well but every ACE showed up here.
You may be correct though as I didn't verify every ACE store in the US.
