Great, that is good solid real world info. I will await further tests and analysis, but if it truly lasts 6 months on its own, then I think it has great potential.
I wasn't trying to suggest it is the same as AW in function (I realize CS is marketed as a sealant, not a spray), just that it appeared to offer similar durability if you read through the lines. If this turns out to be true, then great! While you may not be able to compare sealants to sprays in general, I do believe they can still be compared in terms of protection and durability. After all, I've had AW last longer than some other "true sealants" on the market, so I can't resist comparing other LSPs to it as well, whether they are in the same "class" of product or not. Look forward to further real world testing....
