Brake Parts Cleaner for carpeting (56K Beware)
Read the contents some brake parts cleaner has Acetone in it Acetone can eat some plastics it is called a hot solvent. Some b.p.c. has perchocloride in it that will work fine. It is the same solvent used in dry cleaning
Remember this is a last resort and the mats should be scrubbed before hand. Don't want to make a mess with mud and brake cleaner! :D Also, beware the fumes or you'll be :shocked
The stuff in the pics is actually the same brand I used to use, never had a problem with it ruining any carpet, but it will mess up some plastics, so always test a spot.
Okay--I found the CRC brand that you used Showroom. I have a large stain where one of those air freshners that you stick in an electrical outlet broke and made a mess. It was 'cinnamon" and red in color and nothing has touched it. I suspect it has some oils in it and I am hoping the brake cleaner will work. I am going to try it on some of the carpet in the closet before hitting the stain. Will let you know what happens...
Well, the brake cleaner did not touch my stain. I have tried several other things on it, and I guess it is just one of those stains you don't get up.
However, the brake cleaner did get some marker stains up from my office carpeting!
Al,
The non-chlorinated version is less harsh on plastics. Chlorinated versions can discolor plastic and make it brittle and crack.
I removed a stain that was set in my dad's old Corsica which had been set for years.
I have a lot of dry cleaning so I'm in good with my local cleaner. Go in to a shop that does the cleaning on-site and bring a glass jar with a lid and ask if they'll be willing to give you a couple of ounzes of their dry cleaning solvent and give them $5. The stuff is pretty nasty though. So use some good kitchen gloves (and dedicate them to car cleaning) and use it in a well ventilated area. Works very very well.
Let us know if works out for you.
Paco:
I appreciate the help. I have a local dry cleaner I use that has the service at the store. I will grab a jar this weekend and stop by and see them.
Thanks,
Chewy
Take breaks when using the dry cleaning fluid. The fumes will get you. I believe what you looking for is 1, 1, 1 trichloroethane. Be sure to test for color fastness first. I used it to clean some kind of red stains (it had been there for a LONG time) plus blue stains (from jeans) off of the tan velor of my old Acura Legend. It worked great!
