Bosch 1250 DEVS 6.5 amp...
wannafbody
wannafbody
About the Bosch 1250DEVS Random Orbit Sander
The 1250DEVS multiple-purpose sander from Bosch has two sanding modes: random orbit mode for normal stock removal or fine finishing, and an aggressive "Turbo" drive eccentric orbit mode that operates at five times the regular rate, in order to remove rougher stock. Its simple sanding mode selector switch quickly changes back and forth between the two modes, as your projects require it -- and the powerful 6.5 amp variable speed motor (3,100 to 6,650 opm) matches the tool's speed to the task, for a smooth result on all surfaces.
This model is crammed with great convenience and power features, including a soft start function that tones down the start-up torque and a variable speed dial that makes it extra easy to match your working speed to the project. It also has Constant Response circuitry that maintains the pad speed under heavy loads while simultaneously protecting against overloads, and an integral pad dampening system to help prevent swirl marks -- plus a passive dust collection system (vacuum and hoses required, available by Bosch). The 1250DEVS uses 6-hole, 6-inch hook-and-loop discs. This kit includes a dust tube, soft backing pad, a left or right-hand auxiliary handle, one sanding disc, and a pad wrench (5mm) that stores on-board.
disclaimer: cut and pasted from a product review
After doing some more research I found that this machine only has a 2.25mm orbit. That's probably too small of an orbit for detailing.
At 0.0885 inches, I would say so
Bence said:
That's only the stroke rate = 4.5 mm orbit diameter. Definitely enough for detailing and it will produce wonderful results.
I quess stroke is 1/2 the distance of a complete orbit-correct?
