blue PWC
jimbo_01
when applying this how many coats do you apply? also does it dry to a haze or do you just wipe it off after you apply it? also what would be the benefit to applying this first before i apply the natty's blue?
You would only do 1 coat of PwC becuase the second coat will just remove the 1st. The benefit of PwC prior to nattys would be a wetter look and you would have a cleaner slicker surface to apply nattys on.
Greg
PWC offers some form of protection while PP will leave your paint unprotected. Pro Polish is a better cleaner however.
PP won't hide anything. I actually use it to see if there are any swirls left. PWC doesn't hide a lot either, but it has some hiding abilities seeing as how it is part carnauba.
so when applying this do you let it dry or do you just remove it after completing a panel? the only other polish i have ever used was meguiars show car glaze and with it you just wipe it off after applying it.
As the instructions say on the back of the bottle, there are many ways of using and applying....if you work it and then wipe it, then it will work more like a polish, if you spread it and let it haze, and then wipe it off it will work like a glaze or wax(with filling ability):)
thanks for the info poorboy. i haven't bought the stuff yet. i am very impressed so far with the spray and gloss, and natty's blue. i have some spray and wipe on ordered and hopefully on friday i will be able to order the pwc and the pro polish(for use on chrome and i am going to try it on my glass) i have a big truck show coming up the end of the month and was planning on applying a coat of the blue PWC and then two coats of the blue natty's after that.
Would the filling abilities be the same with both methods of application, or would working it like a glaze be better for that?
No only when applying like a wax...
Poorboy or anyone else that has used the products, what do you guys recomend for a show car shine? i was thinking of the blue pwc and then the blue natty's but wasn't sure if i should use a sealent inbetween them for a better look?
