imported_artikxscout
Very clean. Great job on the car! What camera did you use?
artikxscout said:Very clean. Great job on the car! What camera did you use?
EastsideAutoSpa said:if you dont mind me asking what does a three day detail cost......
artm3 said:amazing work...simply amazing
RickRack said:Glad to see that the Tuf-Buf/203s combo worked out for you. They're perfect for those certain situations where foam just won't cut it.
AlBoston said:I'd be interested in seeing the area that was wetsanded in the sun. I have a feeling it will look very shiny compared to the rest of the paint.
Looks like a job well done.
clcollins said::wow: Awesome car, awesome work
dsms said:Not really sure what you mean by this, what does the "rest" of the paint look like now?
bufferbarry said:what he means by this is that when you sanded it was a little flatter then the rest of the car. because the paint was leveled more with paper at this spot it would be shinier then the rest of the paint. the rest of the paint has some factory orange peel. now for someone to be this critical one a VERY impressive detail is just obsurd. its david sanded one whole panel flat and left of the car with orange peel, that would be different. he spot sanded to remove scrathes. the smart way. if he would have tried to remove it by grinding on it with wool pad and compound you risk burning the paint more. lets not forget david got this job because of his outstanding work. if the last person would have used his techniques david wouldn't of had to do this car. david you executed this detail like a true professional. outstanding results. perfect attention to detail! i give ya another thiumbs up!
artikxscout said:wow great detail. I'm guessing you use the flex for smaller tighter areas? Did you do 1 pass on that hood shot with the wool or are they two separate passes. It seems 1 pass at that size is pretty large for 1 pass.
