Hello Autopians! Though I have been reading your forum for some time, this is my very first post. Every since I bought my first vehicle, I washed and waxed it religiously. However, my techniques certainly could have been better, and after reading all of your helpful information I feel much better about my detailing future. :nerd1:
Last April, I bought a black '08 Jetta. I know it's not fancy, but I love the car and I want it to look its best for as long as possible. I plan to keep it and drive it until the wheels fall off. Naturally, the previous owner did not take care of the paint as well as I would have, and I've been bothered by that since I've owned it for the better part of a year. I'm assuming it went through a lot of automatic car washes. The paint still shines and looks great when the sun is hiding, but when the sun is out the swirls drive me nuts. This is my daily driver, and I have put 20k miles on it since buying it in April. It currently has 62k on it.
I've done quite a bit of homework and research on this forum, and would like to try and get the swirls out. I'm planning on doing this sometime in the next few months. Right now I'm focusing on getting my wash technique right to prevent future swirling. The car is currently protected by a coat of NuFinish. This is the first time I have done anything beyond washing and waxing my paint. Here is my plan for the paint correction:
1. Wash with Meguiars Gold Class
2. Clay
3. Ultimate Compound with orange LC pad (6.5") using porter cable 7424XP
4. Ultimate Polish with white LC pad (6.5")
5. Blackfire Wet Diamond with gray LC pad (6.5")
6. Do I need to use anything else after BFWD?
My main concerns are getting the swirls out with damaging anything, and protecting the paint against the elements. This is my daily driver, and I don't have a garage to put it in. I also live in Alabama (and spend a lot of time in Florida), so it sees a lot of sun. Please let me know what you think about my system and products. Naturally I have a lot of questions, so please bear with me!
1. I had read before that I need to clean the pads often while applying the UC and UP. If this is necessary, how do I do that effectively while working on the car?
2. I know I need to buff each section with a microfiber towel after using UC or UP, but is there anything else I need to do between products? Can I just wipe them off, and then move to the next product?
3. I will be working outside in natural light. I know this is a time consuming process, and it's likely that I will need a couple of days to complete the project. Should I rewash the car on the second day?
4. Should I get 4" pads? If so, which ones, they seem to be totally different from the 6.5" pads.
5. How do you guys handle curves on cars while working? This seems tricky to me.
6. Do you do the small and tricky areas by hand? What type of applicators do you use? are the meguiars foam circle things the ideal thing to use?
7. This car obviously has deeper scratches, will the BFWD do a decent job of covering them, or at least not accentuating them?
I know this is extremely long winded, and I probably still have more questions. When I start on this project, I will definitely post my pictures and results. I appreciate any comments and advice you can give me!
2. Clay
