Big review: Mackees 37 paint, wheel, tire coatings plus others!
Following the directions I cleaned the tires using the McKee's 37 tire and rubber rejuvenator and a stiff bristle brush.
I am a DP Tire Coating user and seeing how the McKee's 37 Tire Coating is similar I figured I would pass on some tips that should help future users. Prior to using the dedicated tire cleaner, I use another tire cleaner to do the heavy lifting. I then come back with a couple rounds of the dedicated tire cleaner. This will save product for those that have bigger tires.
Next I applied the coating using a soft bristle brush.
Immediately after applying.
A brush is the way to go for application. It gives a more even look and requires less product than using a foam applicator. I use the carrand tire brush which works great.
I waited 30min and then applied a second coat and I was left a nice matte shine.
Mike Phillips posted a nice tip in a thread of his. If I find the link I will post it. But I believe it was one of his production detailing write ups. The tip is to use air to dry to speed up the drying and curing process. I have a master blaster sidekick and it's a great tool to use to speed up the drying time. It also spreads the coating around into those nook and crannies.
http://www.autogeekonline.net/forum/ask-mike-phillips-your-detailing-questions/88914-2013-camaro-rupes-production-detailing-mike-phillips.html
Glad the tire coating was kept around in the line. It's a great product.
Edit: Added the link to Mike Phillips' post.
Awesome input Guz. I would normally do the same thing for cleaning the tires. Sense these don't ever get bad the McKee's did the trick.
