I've had pretty bad success with spray waxes in the past(ie. NXT Spray Wax). I was at Kragen the other day picking up some Eagle 1 Spray Detailer and I came across Reflections Spray Wax. I like the original wax and thought I might give this a try.
So, I usually take a meguiars foam pad and spray some wax on the panels and then rub the wax in. I let it haze and then tried to wipe it off. I know the original wax is super easy to wipe off, even if you put a lot on. Well, when I tried to wipe off the spray wax is seemed like it was glued on there. I needed to spray some qd to loosen it up. This was a lot harder than just regular waxing and I thought spray detailers where suppose to be quick.
My question: What is the best was to get a thin layer using spray wax?
