Accumulator
Well-known member
jlau said:The Klasse AIO is not good to apply by hand and that it does not hide swirl marks?
AIO works fine by hand but doesn't do much hiding at all. I'd choose Autoglym Super Resin Polish if you want concealing from an all-in-one product, but again, I'd just use a 1Z polish instead.
Is using Pinnacle cleansing lotion, Klasse AIO and then the Souveran carnauba wax good to apply by hand?
Those all work fine by hand.
What is a good quick detailer and clay to use? Is clay only for taking out things that are on the paint that is not clean in the wash? Is it okay to clay the car everytime apart from the time that it takes? Thanks.
I use Sonus green (ultra fine) clay with the Glyde lube. For a QD there are countless choices...I probably use FK425 the most. You can clay as often as necessary but overdoing it (or doing it aggressively) will remove LSP as well as contamination.
