imported_Automania1
TOGWT said:OP - Folex
Coffee will cause an immovable stain if left to ‘dye’, so remove as soon as feasible. All-purpose Spot Lifter is a strong, but safe, multi-stain remover. It may be used on any surface in a vehicle, office or home. We offer it as a problem solver for carpet and fabric upholstery. It's also great as a pre-spray for carpet cleaners. Water based pH 9, (citrus) spot remover effective on oil and water based stains such as blood, soft drinks, light grease, oil, tar, coffee, tea, floor finishes, copier toner, spills, dirt, grime and more. Don’t forget the carpet padding, once treated allow to dry thoroughly before replacing the carpet - TOTL.
Stains, Rings, What causes them?
Now researchers have discovered a surprising twist that changes our understanding of how these stains form. It turns out that liquids, such as coffee, that are made up of spherical particles dry differently than liquids with more oblong particles, scientists have found.
In the case of coffee, each particle, or clump of molecules, is roughly a micrometer (one millionth of a meter) wide, which is about 10,000 times larger than individual coffee molecules, researchers said.
As a drop of coffee dries, liquid evaporates more efficiently from the drop's thinner edges. Liquid in the middle then flows outward to replenish the edges, carrying the suspended solids with it. These are then left behind in a ring around the edges of the drop when all the water has evaporated, leaving the telltale dark halo at the drop's edge, with a more translucent center to the stain.
Researchers assumed that particles that were oblong, rather than spherical, would behave similarly. To their surprise, they found instead that oblong particles tend to clump together much more strongly than spherical particles. This clumping hinders the flow of liquid from the middle of a drop to the edge, thus distributing the solids more evenly as the drop dries, and leaving behind an even stain without the ring effect.
"I think people are very surprised that by just changing the shape of the particles without changing the chemistry, we're able to avoid this effect," said University of Pennsylvania graduate student Peter Yunker, who led the research.
The revelation could be of interest beyond the physics *
Coffee stain rings: So here's what causes them - Technology & science - msnbc.com
Removing stains can be difficult due to the natural tannin in coffee. As well as the hot coffee when spilled opens the microscopic dye sites in the fiber causing them to burn or absorb the tannin permanently staining the fibers. Often, coffee stains must be removed at elevated temperatures close to the temp at which they entered the fiber to remove them. Remember using a high level pH cleaner will set a stain.
