duke4ever said:The thing with bugs is, their shells is made out of chitin which is an organic compound, regardless of the acidity of their body fluids, you can't get them 100% removed (with a non organic surfactant) IF the exoskeleton somehow imbeds itself into your clear coat, which is possible. At a decent speed, a bug splattering on your paint will embed it nicely.
So, there's 2 basic scenarios:
The bug is on your paint but only superficially. In this case you'd want to make sure you remove it immediately and/or bring the ph up till the time you can remove it so it doesn't hurt your paint. A simple water based cleaner should be able to remove the bug in this case.
Second scenario, the bug's embedded in your paint. This is a little more tricky.
Let's examine what's going on here: The acid is eating away at your paint slowly, this combined with the velocity of the initial splatter causes the bugs exoskeleton to embed in your paint causing it to *stick*. This is why you get pitting if you leave the bug long enough.
At this point it's important above all to dissolve the insect body, the hardest substance, chitin. Chitin is mainly N-Acetylglucosamine, that is, it's organic , but more importantly chitin on a bug has a highly crystalline structure (it's a protective shell after all). This reduces its solubility in water. Given that, how do we dissolve an organic compound? With an organic solvent. TW contains a few organic solvents: Turpentine, 2-Butoxyethanol, and Stoddard solvent. These solvents will dissolve the chitin in the bug shell lifting it off your paint. Allowing you to remove it.
In and of themselves, these solvents are not abrasive. The TW bug remover would have to contain some abrasive of its own if in fact its causing micro-marring.
There could be another explanation though: It's possible as the solvents dissolve the chitin and the action of you moving the cloth back and forth is causing microscopic pieces of chitin to rub across the paint as you wipe. Chitin being a hard crystalline material has the potential to mar your paint.
There could be more going on, the TW stuff also contains paraffin, but so do some roach sprays and candle stuff, so I don't know if this is having a filler effect or an effect on the bug itself...
Wow, what a great explanation. I want to memorize it and dazzle people when they come up and ask me about bugs on their car and why they hurt the finish. However, I'm sure it would come out something about chitlins, turpentine, micro-organisms, and dropping acid.
