Best Interior Glass Cleaner
jmsc said:
For those who use Prima Clarity from Detailer's Paradise:
1. are you using the DP Norwex glass mf or some other mf to achieve streak-free glass?
2. if Clarity (quite inexpensive by the way) does not contain alcohol nor ammonia what's in it that makes it work?
I just use a WW MF from Pakshak or fiberworks. The same I way I cleaned when I used NXT. It is very cheap by the gallon, i would get the sprayer as it is the best I have used so far. As to how it works ask Nick, [email protected]. He is very helpful and quick to respond.
Guy said:
I was a IG user until I tried NXT. As stated earlier it doesn't have a strong cleaner so I use windex first then the NXT. I've never had that clean streak free glass with very little effort as this!
Do you really use Windex on interior glass? Aren't you worried about harming the tint?
ig is good stuff, but for some reason i always reach for my bottle of white vinegar/water cheaper that ig. use a good mf or even newsprint never seen a streak on my end. i also think it eliminates the tar film from smoked in cars better than ig.
Windex wont hurt factory tinted glass as the tint is IN the window not ON window like aftermarket tints.
Windex is strong stuff. If you get it on the back of a mirror it will lift the reflective coating. Years ago I used the same towles to wipe down the dash on a 90 Linc. T.C. after washing the windows. I swear that the windex was the cause of the chrome plating flaking of the plastic dash parts.
I still use it at times but am carefull to keep it off the interior & dash.
