Best air inflator/compressor under $100
Spilchy
The air hose at the gas station 1 minute from my house is broken.
What is the best inflator out there that is under a $100?
Any ideas?
Sears has a nice collection of inflators. I got my friend one for about $30 and it works well. They had it ranging from $20 to $60 so check them out.
I have a Sear Craftsman Inflator/Compressor and I love it. Its perfect for what I need. It has a built in gauge, its AC powered, and comes with several attachments.
Perfect for tires, inflatables, etc.
I am also looking around for an inflaor for the past 2 years and could never spring the cashfor the oil driven uprights I really want. I am looking for a compressor with enough pressure and air flow to blow out a cars crevices as well as workbench sapces and dirt on the floors. i need the air to really move. Do they make something that is priced in the middle of the road? $150-250 is ideal?
Ryan
Ryan,
Did you ever find a compressor as you described? I am looking for one for the same exact purposes!
I have selected and purchased a Campbell and Hausfeld commercial grade dual tank (only 4 gallons) 6.8 CFM 150psi compressor at Home Depot. It is great! It can run most rotary tools. I got it for $250 and as a pack deal came along with 4 air tools to boot (Air ratchet, impact wrench, air gun and tips, and, I forget the name of the tool- a tool for taking lugs off wheels.
As a matter of fact I tried it out tonight and can really move air with the air gun. Only downside is the small tank and the noise from the motor kicking in to fill it. Quiet though compared to the standard compressor. Also a 3 year warranty.
Ryan
Ryan
If you would like to make a garage set-up for your compressor and give it a bigger air supply(volume,airtank) its quite simple.
If you can solder copper pipe you can create a system that will act much bigger than just you compressor. I like copper pipe but I have seen guys set ups with pvc. copper though its easier to make water drains.
I have air station 'hookups' all around my garage and turned my 30 gal unit into one with 70 gal of air including pipe. I can just hook up what ever I want and have air power right there no need for long hoses.
My dad had a 80 gal water heater in his garage as his air tank filled with a 20 gal compressor.
Air tools make things much easier.
Ryan your tank could turn into a about a 12-15 gal unit.
The inflator I bought is great but I regret not checking out Walmart sooner because they have a nice compressor for under $200. I suggest you check it out. I also found a new C&H pressure washer, gas, 2000 psi for $200. This is a good price and will outperform all electric units.
Ryan
I recently bought a small compressor from AutoZone that runs off 12 volt power. It's been pretty useless to me because it keeps blowing fuses. I installed fuses with a larger amp rating but it blew them also. I've now decided to buy one from Sears that runs off AC!!
A 4 gal. tank is useless in my opinion. I bought one a few months ago and it really leaves a lot to be desired.
Speaking of Sears... if you have a Sears service center nearby go check it out, I saw a nice big upright there for $250 a few days ago, it was there because it had a few shipping scratches (big deal!) Unfortunately it also had a SOLD sticker on it! DAMN!
