Autobrite Foam Lance (in action)
who actually do i purchase from, autobrite or polish bliss?how much would it cost shipped to nj?i have a honda gas p/w with the quick connects, what do i need to hook it up to my gun.They look so cool and iam sure it cuts down on wash time.
PolishedBliss.com - Website Currently Unavailable, they are located int he UK
If you need any adapters, Karcher Pressure Washers, Karcher Parts, Karcher Accessories, Karcher Power Washers and Pressure Washers is a good site to find what you need. The foam lance has a 1/4" female inlet. I wasn't sure on exactly what to get, so I called their tech support and the gentlemen that assisted me was very helpful. I ended up ordering an addition trigger gun to have dedicated to the foam lance. I picked a gun that has a 3/8" water inlet and 1/4" female outlet. A male to male 1/4" coupler so that I can screw it in directly to the lance.
FITTING, HEX NIPPLE 1/4"MX1/4"M BRASS
GUN, AL5
COUPLER, SOCKET 3/8" MPT
rockz9 said:
thanks michakavelli........do u know about how much total it would cost shipped to nj?
If you add the lance to your cart on their site and put it your specific info, it will tell you. Just keep in mind that once place on your credit card it will convert to US currency. Last I looked the conversion was around $1.43 US to 1 Pound.
While you are there you may want to pick up the 3M Backing plate for your rotary if you have one.
3M 125 mm Perfect-it III Rotary Backing Plate - 5/8"
you must be a mind reader, i was looking at those b/p i currenty use the edge system on my rotary... what size pad would i need for those small b/p?
GUN, AL5
I also ordered a seperate trigger to dedicate to just the lance with the 3/8 inlet, 1/4 outlet and the 1/4 male disconnect.
The 5.5" pads work well on it. Even the 6.5" will work, but I like a backing plate that covers most of the pad backing to ensure even pressure during use.
michakaveli is the licence plate in front what I think it is?? If it says PL than I'm not the only one here:laugh:
And I thought that I'm the onyl crazy polak in here:p Where did you found this licence plate? Is it from the "old" country? I would like to get one of those.
WhiteStripes said:
Dang, that Optimum really gets foamy.
+1. Very impressive indeed!
I use the Optimum soap in my Gilmour. It's clearly one of the superior products in terms of foam, lubricity and over all performance.
I like the foam lance, Chris. My only issue is that I don't keep my pressure washer out and only haul it up from the basement when I need to. I guess I'm unwilling to haul it out for weekly washing. I like to have a few tasks lined up before making the effort.
dc5itr329 said:
hey can you tell me where to get the foam cannon for 70? I've searched around and haven't found it for that cheap
You won't find it. That was a one-off from another member, where the intially picked it up from PolishedBliss.
Good Luck!
Good Luck!
darn. lucky for you. There is a person in locally has it but it's 130 bucks
