Attaching foam pads to PC and G110?
ohiostate
Couple of noob questions here....
-do you need to buy special foam pads to attach to a PC or G100?
-how do the pads attach to a PC and G100 (same way)?
-can they fly off?
Thx!
The pads attach to a backing plate which is attacted to the pc. There's a velcro backing on both the pads and backing plate. And no they should not fly off.
Ok thanks...
trippmann said:
on my PC, the 4 inch lake county pads fly off if the pad leaves the paints surface. not my 6 inch pads though.
I plan to use the 5.5inch pads
ohiostate- I find that pad *can* fly off the PC if I try to spin them dry; it works fine with a rotary and with the Cyclos, but not so fine with the PC.
thanks again Accumulator... I think I will be looking into the G100... but we will see
