OK so here's my conclusions about Aquartz:
applying AQ+ with the rotary (even at low speeds) left holograms all over my perfect finish! Supposedly the AQ+ contains no abrasives, so the only thing I can think of that left holograms was the Aquartz itself, by spinning thousands of nano particles around together and them making sort of a "nano conglomeration", which marred the finish. To say the least I was thoroughly pissed and tried to jewel out the damage with AQ+, but to no avail. It took me another 3 hours+ to remove the Aquartz and to polish out the holograms...
I noticed that the Aquartz alone was leaving a less than desirable finish... Basically it was leaving a "greasy" film all over the car that couldn't be wiped off, spread out more smoothly or even dried with a heat gun. I noticed that once it was applied and I let it "settle" for a bit, it would sort of "calm down" and smooth itself out, but the second I touched it I had "greasy" smears again. Very frustrating...
As far as durability is concerned, well Aquartz lost an "Accelerated APC War" with 2 other coatings (Nanolex Professional and "the secret stuff"). I let all 3 coatings cure for more than 48 hours and then washed them all with a 1:1 mix of APC... Aquartz lost in round one
, while the other 2 still possessed adequate sheeting properties even after 3 "brute force" washes...
In conclusion, I do not recommend using this product
I also spoke with a few other people and they basically had the same experiences...
