Kean said:....some products are easier to wipe off than others. For example, a product like Black Wow can be a bit of pita to completely remove from glass and paint so extra care should be taken. On the other hand, something like 303 can be wiped up relatively easily. Using an appropriate applicator for the task can also help. I usually do it free-hand and then if necessary, follow up any minor smearing with an MF dampened with QD.
....I typically apply protectant/sealant to the trim on my vehicles every other wash or so (before QD'ing if I even do). When polishing/waxing, the trim bits that I might use 303 on (that I don’t use a sealant on) are typically done after applying the LSP or during down-time as the product cures/dries (if layering). ....it really depends. I'm just a DIY'er/enthusiast so I don’t adhere to a strict regimen. In the end, you need to find a routine that works best for you.shadow85 said:Do you usually do the wax/sealant first or the 303?
jaymz said:I use those little foam paintbrushes to apply plastic dressing. They're cheap and work great.
Jim
