APC suggetsions
9935annivgt
I am looking for some APC suggestions for cleaning and would also love some suggestions on dillution ratios. I am looking primarrily for interior (dash, console) and rims and or engine. Thanks for any help you can give
megs apc+ and it can be diluted from 10:1 (medium duty, interiors) - 4:1 (heavy duty strength). love this stuff and i'm on my 3rd gallon if that means anything...
Megs APC+ is one of their best products. At 20:1 it is safe to use on leather, at 5:1 it is my go-to wheel cleaner. I use it at 20:1 on interiors and 5:1 on the outside of the car, the engine compartment, underbody, wheels, tires, etc.
I've been in love with Optimum Power Clean and recently had the chance to put it's cleaning ability to test against Meg's APC & Super Degreaser on a vehicle that was nearly 40 years old. OPC was noticeable stronger, easier to use and all around cleaned better. Tested it on the undercarriage, wheel wells, engine, wheels, tires and complete interior. The other person I was working with couldn't believe the difference either.
I found Optimum can clean tire brown much better than Meg's APC. It just seems chemically different than all the traditional APC's in how it feels and woks. For example, when I spray OPC the tire does not seem to drip brown crud in the drippings like most APC's but it spontaneously comes on with the rinse.
I keep Meg's around for carpet and light cleaning since it is more cost effective so OPC is for the tough jobs.
I've been using Top of the Line's APC (TOL APC) for years. I like it a lot. It's uber cheap too IIRC. Haven't bought it in forever.
You're totally right. This product ins't like any other I've used.
Quote from David:
That wouldn't happen to have been a Porshe - was it?
For those that have used both megs apc and apc+. I know apc has better foaming capabilities and has softeners. At the same dilution ratios between the two, is apc+ actually a stronger cleaner? What do you guys prefer?
i have used gallons of both apc and apc+ and prefer apc+. it is a little stronger (it orange and smells like oranges, so i assume it's citrus based) and i like it better overall...
