Any tips for applying BF wet diamond with PC?
svtcobra
Just finished applying Menzerna Power Finish PO203. Thanks for the suggestion Todd....worked great.
Now I'm going to apply the PC with BF Wet Diamond with Lake County Gold pads.
Any suggesstions or hints on techniques?
1) Should I apply the same pressue as with the Menzerna po203?
2) Should I apply the wax at speed 2 for 60 seconds and then increase the speed to 5 and work the same way I did the PO203?
3) When applying the wax at speed 5 should I move a bit faster rather than slow like with the polish?
Thanks any help would be great.
No pressure is needed for applying sealant, just the weight of the machine.
I always apply wax or sealant at Speed 3 or 4 and I don't change speeds.
I apply sealants quickly in a fairly thin layer, overlapping slightly. Only apply to the area once... don't go back over it like you would with polish.
Let dry a few minutes and wipe clean with a microfiber.
