David Fermani
Forza Auto Salon
paco said:In my opinion, it really depends on the weather in your area. Personally, i'd only do it very very rarely over the winter for the following reason.
1st (and foremost), water will "activate" the corrosiveness of salt. If the weather stays below -5C, it's probably better to leave it alone.
Isn't the humidy in the air already "activating" the corrosiveness of salt? Salt corrode bare, uncoated metals immediately.
paco said:2nd Touchless drive through washes or high pressure hand wash bays will push salt and sand deep into crevices that probably won't be washed by hand until the late spring when you can detail your car really carefully.
Unless you're completely removing the body panels off your vehicle, any kind of washing pushes the elements into cracks and crevises. It's also getting pushed just as hard when you splash through slush and salty water puddles. If anything, high pressure washing will flush out hidden areas better than anything.
paco said:3rd The detergents in most are very very harsh. Citric acid isn't uncommon. So by washing at one of those locations, you're pretty stripping the protection from your vehicle and then pushing salt solution deep into your car joints etc. Outside of the flat panels of paint, your pushing into the hinges, undercarriage etc.
Again, at the end of the wash cycle you're also flushing out all the remaining loose debris and soaps from these places. I'll take these so called harsh detergents being pre-soaked and blasted into my finish over salt coating it any day.
paco said:Repeated use of those can really do far more harm then good over the winter.
It would be great if you could elaborate more on this. I don't feel it's accurate.
paco said:Last year I handed back an Acura EL (4-years) and it didn't have an specle of rust and i typically only washed 1x per month in Dec, Jan, Feb and March. The car was 99% swirl free and ultra smooth. The dealer was "shocked" how well it looked. They typically don't have cars in the showroom or delivered that was soo well cared for. I only polished it 1x in 4 years with a mild polish.
My mother's Mazda3 NEVER gets washed during the winter and i do a full detail in May and it's 5 years old now and in perfect condition. 95% free of swirls/holograms and not a dot of rust.
The same could be said for many vehicles with the exact opposite regiment. Actually, I can't remember the last vehicle I've seen that was produced in the 2000's that was rusted? Especially one that was washed regularly.
paco said:However, if you have a indoor garage and want to hand wash, then that would be fine.
How is this any better/safer than any other kind of washing?
Egoolps said:If you HAD to choose between:
1) Using a touchless wash
2) Getting a hand car wah (not by you of course)
What would you choose?
I'd rather go through 100 touchless washes instead of 1 hand car wash. I'll take a stripped finish over one that's marred from some hack making $8 per hour washing cars.
