Setec Astronomy
Well-known member
That`ll happen. At least it`s usually not a highly visible location.
You can get away with a screwdriver if you use the "bottle opener" trick (like using any non bottle opener to open a bottle) - Place the tip of the screwdriver under the weight, then lever off your finger to lift the tip vs just driving it under the weight. Hopefully that`s a coherent enough description to make sense...
I have two tools in my Amazon cart, the "bone" one you mentioned and another one--so I`m good.
