HondaMan
2004 Civic EX magnesium
In the past, I've been a guy who like to use too much rather than too little product. I'd glom it on -- and if it was tough to remove by hand, I didn't mind (I figured it was a sign of extra protection and toughness I had applied).
Any thoughts on the following amounts I used:
(1) I used nearly a whole bottle of clay lube on 2 cars -- did I overdo it or is that the right amount? I may have overused, as I didn't want to risk roughing the clay over the car (esp. my new one) since that was given as a warning to avoid.
(2) I'm guessing, but it looks like I used about 1 ounce (maybe a bit less) for each of the coats of Klasse AIO (about 1/8th of the bottle used for 3 coats so far). Does that sound about right or should I have used more (remember, I did a Civic and a Camry).
(3) UPP: Looks like I used a bit under 1 oz for each run, about 0.75 ounces (3 coats so far took up about 1/8th of the bottle again). Too little UPP or too much or right amount?
(4) PC with SSR: I'd say I put 5 or 6 drops on the applicator for each 2 or 3 foot square section. Looks like around 1 oz for the 1 use I did, maybe a bit less judging from what's left in the bottle. Too much or too little?
I don't mind using more if that's a "better, thicker coat" -- I don't mind removing the stuff with elbow grease and in all honesty, the MF towels really made taking off stuff alot easier than I remember doing this regularly 15 years ago.
