i m no expert but i thought if you have polished to perfection than a glaze isn't needed. however. if ez creme is similar to enhancing polish than this type of glaze would be apropos as a gloss enhancer before bfwd... now in the case of the original question the alchohol is 70% and the dilution ratio is 70/30 not 50/50...
Yeah, guess the $ was burnin' a hole in my pocket and had to spend more $ on something I really didn't need! :doh:
As long as you use an Acrylic based glaze (like EZCreme Glaze), you will have no problem with the sealant bonding to the glaze. If you put a glaze over the sealant, it will only last until it rains next.
This is true. I was going to mention the only only time I'd lay a glaze down first was if it was Danase Wet Glaze which is an acrylic glaze but I forgot to mention it. Normally glazes can have a lot of oils and or fillers in them so obviously you can't expect to have a sealant bond really well with the paints surface when you're putting it on top of something oily. As was mentioned, an acrylic glaze is the exception yet I'd personally still put the sealant down first.
I've never hear of a "glaze" being left behind as a result of polishing. They are generally 2 different things with 2 different purposes. The second thing you said makes no sense at all so whoever told you that mixed up what they were saying or you misunderstood. You said "If the polish has a glaze in it then an alcohol rub would remove the glaze put on by the polish, so you would not want to do the alcohol rub." To me this makes absolutley no sense. The whole point of polishing is to remove scratches and swirls. Glazes are generally used to hide or mask scratches and swirls. The reason you use an alcohol/water mix on the car after each panel is you WANT to remove any polishing oils because you want to make sure you actually got rid of the scratches/swirls and that you're not just filling them in a little because that defeats the whole purpose of polishing. If a polish left a glaze behind and you weren't supposed to do the alcohol wipe down, how would you know if you actually corrected the paint or just camouflaged the scratches/swirls with the glaze?? You'd have to see this is common sense.
I will comment on this...... as I took some heat in the past from a select few for using CG EZ Creme for filling. I utilize the IPA mostly on jet black or soft paints where you will run into problems or when the weather gets hot and polishes can act up on certain finishes(Which is really a problem for those of you in humid climates such as the "J". Todd and Bing in Orlando, Bryan in Atlanta and also Dave F in S.Florida, Barry in PA, Marc & Jacob in Detriot ect...
I put distilled water in with the IPA in a squeeze bottle, and use just what I need on a finish microfiber to the paint to confirm the finish is "Good to go", then AFTER everything is corrected I use the Glaze to pop the finish and add some slickness as well and have never had a issue with any LSP bonding or doing funny stuff. :2 cents:
