SayNoToPistons
I decided to take the seats out of the Infiniti and i had to unplug the harnesses (power, heat, and side airbag). I took them out because it was 20 something degrees out and the leathers seats were dried and dirty. I cleaned/conditioned everything up and bolted them back into the car after replugging the harnesses. I did try turning on the car before i had the seats in so i can move it up the driveway and of course I expected the airbag light to blink without the seats in.
Everything is back in place and I fired it up. It threw the air bag light. I reached under the seats (without removing it) and tried my best to wiggle the connectors in place to make sure they're set. Fired up the car again and the same thing happened.
I was told to leave the car overnight with the battery unplug so i did that. Woke up the next morning and plugged the battery back in place and it still threw the light.
I was also told to disconnect the battery and touch the cables together to "discharge" the capacitors. Same thing again.
What's going on and what can I do to fix it? It's a 2001 Infiniti QX4 BTW.
