from what I understand, Menzerna does not contain fillers or oils, so it seems that you could go directly to SG, but I have not tried it. I know what you are saying after the IP & FP, the finish looks great, I have however used UPP after Menzerna with no problem, but of course it is different than SG.
Glad to hear the Menzerna worked well. I highly recommend you use AIO on your red car...I just did the same on my red car after similar polishing results and I thought I could skip the step. I didn't and I think the results were great.
I'd recomend you use jimwh's Klasse instructions in the "hall of fame." I had a small issue with SG and a little hazing but it was because I hurried so I'd also recommend you stick to the 1 hour dry and 24 hour cure times with a little more/less depending on the humidity.
