Afraid of my water tank freezing
RenuAuto
Headin up to some colder climates this week. Wondering if there's anything I can throw in my water tank to ensure it won't freeze? It's a 35 gallon tank and I do most my washes via ONR now.
Thanks!
Grant
I think the only thing you could add would be anti-freeze or alcohol. Neither of those things would be very desirable in your water.
Oil pan heater plugged into a 250 watt DC/AC inverter running off of 12V from your battery. Stick the oil pan heater (it's just a flat rubbery pad) on the side of the tank.
We use them up here to keep our oil from turning into glue at -40 degrees.
Drain the tank nightly, fill it the next day with however much you think you'll need. Keep the tank spigot and hoses dry/clear so they don't freeze up, and run antifreeze through your power washer.
