cheapshot said:does optiseal have any cleaning ability?
I once put #16 x2 over VMWHG. It looked great!
Acually it looked great after #83 and #80.
Ambrosia said:Make sure you go over the Opti-Seal with a MF before you apply the wax to get any streaks out, which is pretty common with Opti-Seal.
:think:mshu7 said:As some one else mentioned, apply OS with a MF applicator instead of a foam applicator.
Scottwax said:If it is streaking at all, you are using too much or whatever product you used to prep the paint was not completely removed prior to applying Opti-Seal. I *may* get a random streak every 3rd or 4th vehicle I apply OS to and it is always operator error.![]()
a.k.a. Patrick said:Also use the OS with a MF instead of the foam applicator...
:think:
The Meguiars foam hand applicators are absolutely ideal for applying both Opti-Seal and Clear Seal. I am getting 10 vehicles per ounce of product using the Meg's foam pads and no streaking.![]()
:think:
itb76 said:I just tried this last weekend; it worked much better for me than the applicator that came with the OS. Much easier to use.
Scott, I wish I had half the talent you do for detailing cars. I'm sure the applicator is how OS is designed to be used, but for a relative noob like me the MF made the job easier. The applicator will grab the paint sometimes and fly out of my hand, while the MF glides over the surface. If it costs me a little more product to use it this way so be it.
