The title should give you the idea. Having started to build the pads collection, I also jumped into getting a rotary. The pads I have so far are 6.5" and my backing plate is 5" with 5/16-24 male spindle (attaches to the PC)
I somehow got the idea of using the backing plate with the rotary also. Surfing before I found this adapter from detailers paradise 5/8-11 adapter However, this is in fact for the opposite case: using a rotary backing plate with a PC. Talking with Nick (DP owner) I mentioned that I think the opposite adapter is a better idea, as it is more likely that someone who owns a PC will get a rotary later, rather than someone who has a rotary getting a PC as addition. Another factor is that rotary backing plates are usually larger and heavier, not a good combination for PC vibration. Nick agreed.
Well, I got the adapter, I got myself some coupling nuts and I use my PC pads and backing plate with the rotary. Little problem is the total lenght of the adapter plus the coupling nuts is over 5 cms (2"). Longer shafts induce more jumps. I also asked some local iron worker to weld a regular 5/8-11 nut to a 5/16-24 nut. The inconvenient here is that the operation has to be very exact. If the nuts are not exactly concentric then you also have additional vibration in the rotary.
Does anyone know if a straight adapter exist to use a PC backing plate with rotary? Has a company thought of creating such adapter? (maybe DavidB can sell it ;
In the worst case, I would like to get a flexible 5" backing plate for the rotary. I don't want to get a complete new set of pads and backing plate for a device that I don't use that often.
Suggestions are welcome as usual.
Alex
Alex
