Nickc0844 said:
gbackus--
Then why are you complaining about how Poorboy's is difficult? It doesn't get much easier than Adam's or Poorboy's? You have contradicted yourself, bad mouthed both companies, and frankly, I've lost all respect for you on this board.
http://www.detailcity.com/forums/showthread.php?s=&postid=33998#post33998
Good luck in your future endeavors!
How did I bad mouth poorboys? I realize that Pro Polish can be hard to use, and SSR1 is much easier for
ME to use. I probably am using too much Pro Polish, and that seems to be a common problem, people using too much, and the product being hard to buff off. I'm not the first, nor the only person to experience this on the board. I never said it was a bad polish, I love the clarity it gave my paint.
As far Adam's polishes goes, it could very well be the applicator pad and not the Polish itself, as I stated, I got good with results with the polish and the PC, but still get the same results with the applicator pad. Yes I do mist down the applicator pad. I've gone through GALLONS of his detail spray following his directions to a T, misting the applicator pads to aid in applying the polish, as well as using the detail spray to aid in the removal of his polish, and the butter wax.
Please tell me how I've contradicted myself? And respect? Please, this is the internet, we're all here to share our experiences and results. Because mine differe from others my input is not valuable? You obviously get good results with you use, and I've still learning how to use what I have.
To answer you're other questions, I'm still using the Butterwax as a topper for PWC. As per someone elses recomendations, I washed the car the day after, and dust attraction is far less now than it normally is, though as others have mentioned, that could've been due to static charge.
I will agree with you on the brilliance, I haven't found anything to clean my glass as well, and haven't had a time to pick some up.
