joyriide1113
There is no cure!
Dwayne said:Without the spinning, the pad and product will do nothing. To say that the holograms are not caused by the spinning action is not entirely correct. Sure, you can use an old wool pad and a very abrasive compound and get much more paint damage or you can use a soft finishing foam and limit the amount of holograms but the spinning is what causes the holograms. That is why Fuzz recommended the dual action PC. Finishing and polishing with the dual action polisher is the perfect solution to holograms or buffer swirls.
Here are a few questions the detailer should ask themselves...
Why try finessing swirls and holograms out of paint with more heat and cutting than you have too? Why use a machine that, in the wrong hands, can cause damage. Why not use a machine that is much more idiot proof and can polish paint without the risk of burning through or leaving behind holograms and swirls?
The rotary polisher has it's place, but the PC dual action polisher is very popular for a very good reason.
thanks dwayne. very insightful. never thought about it that way.
but how do detailers like gr stilez finsih with the rotory with almost perfect results and i can't get it down. i mean i practice all the time. and at the end just quit and finish with the pc.
ill stick with the pc until then
