RZJZA80 said:
So 3401 doesn't instill holograms? I don't understand the science behind this as forced rotation to me is another way of saying rotary, or am I getting it wrong?
There are still two actions going (elliptical + rotation) on rather than one (rotation) so it's different from the rotary (which only has the rotation).
The forced rotation doesn't make it a rotary, just keeps it from losing the rotation the way a PC/etc. can under pressure (and makes it do that part more aggressively when it's not under pressure too).
I use a Makita 9227 and GG6, but if a Flex does was a rotary does and is that much easier, I'll pick one up.
I hardly ever use the Flex 3401 since getting the GG 6", but then I don't do a lot of aggressive correction any more either. The Flex will do aggressive work considerably faster than the GG, but not as fast as a rotary (with very aggressive, rotary-only combos).
Edit: I only cut with my Makita, I still always finish with the DA, so if I hologram with the Makita, it's ok with me.
That's the way I did it before I got the Flex 3401. Now my Makita and Metabos basically just sit on the shelf, even when I do have a job that requires really aggressive correction.
Besides the lack of holograms, the Flex 3401 is *much* more forgiving with regard to having and "oops!", not that I ever thought the rotary was all that tricky in that regard. If the rotary is basically Accumulator-proof, the Flex is pretty close to idiot-proof (depending on the idiot in question, of course).
Now whether you should spend *your* money on the Flex...well, I dunno :nixweiss I simply don't like my rotaries, so it was worth it to me. But if you're happy with your Makita then I wouldn't try to talk you into the Flex 3401.
MCA said:
...honestly i haven't noticed any difference on finishes between it and my PC. I think finish has to do more with the product/combination/technique than anything else.
After going around and around with
John Kleven, not to say we really :argue or anything, I started really paying attention to this. I gotta say that I simply can't get *quite* the same finish with the Flex 3401 that I can with either the Griot's 6" or the Cyclos. No matter what pad/product combo I use. The diff is pretty subtle with products like Menzerna and 1Z High Gloss, but I do still see it, which was *NOT* what I'd expected when John and I first discussed the topic.
I haven't finished via PC for so long that I can't say how that machine would compare. After getting used to the Griot's I simply can't stand to use the PCs any more, not even for spot-corrections with little pads (got a Griot's pneumatic for that).
