Setec Astronomy
Well-known member
Any news yet on what broke?
We got an Escalade for 3 days to toot around in
GSRstilez said:The Escalade was fun while it lasted. Very quick, might I add, too.
ebpcivicsi said:Wow!!! Got Camber???![]()
splattj said:Did you have this recall done?
Product Safety - Lower Control Arm Washer #04043 - (Aug 18, 2004)
04043 - Lower Control Arm Washer
2004 Cadillac CTS, SRX, XLR
Condition
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 2004 Cadillac CTS, SRX and XLR, and Chevrolet Corvette vehicles. Washers that are used along with nuts to attach the lower control arms were made of the wrong steel material. These washers may fracture and become loose or fall away from the vehicle, making it possible for the control arm to separate. If this were to occur on the front of the vehicle, the affected corner of the vehicle will drop and the affected wheel could tilt outward, creating a dragging action that would tend to slow the vehicle and turn it in the direction of the affected corner. The driver could maintain some steering control with the unaffected wheel, but the vehicle control would be diminished. If the separation occurs at the rear of the vehicle (XLR and Corvette only), it could cause unexpected right or left lateral forces at the rear of the vehicle. Although steering of the front wheels would be unaffected, control of vehicle direction would be impaired.
Front or rear control arm separation may also reduce brake system performance and increase stopping distance.
If these events occur and the driver is unable to react in time, a crash could occur.
Correction
Dealers are to install a new nut and washer, and if required, replace the ball stud and/or steering knuckle.
Vehicles Involved
Involved are certain 2004 model year Cadillac CTS, SRX, XLR and Chevrolet Corvette vehicles built within these VIN breakpoints:
Year.......Division...........Model...........From ...........Through
2004.......Cadillac...........CTS..........4014876 0........40183479
2004.......Cadillac...........SRX..........4014876 2........40183477
2004.......Cadillac...........XLR...........456017 54.......45603310
Important
Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) before beginning recall repairs. [Not all vehicles within the above breakpoints may be involved.]
Important
Less than 1% of the population is expected to require replacement of the lower control arm and knuckle.
armoredsaintt said:wow the CTS has 4 wheel steering like the GMCs Hydrasteer system![]()
